HP Compaq Presario V6000 Wifi antenna card Replacement
  1. HP Compaq Presario V6000 Wifi antenna card Replacement, Wifi antenna card: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab a Type-Cross #1 screwdriver and unscrew the 3 screws and take off the cover of the wifi antenna card.
  2. HP Compaq Presario V6000 Wifi antenna card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your finger tips to pry off the gray antenna connections.
    • Be careful to not pull the antenna wire too hard, you may cause damage to the connection permanently and/or motherboard.
    • The screwdriver is only being use to demonstrate which wire to remove. The screwdriver can potentially damage the motherboard if used improperly.
  3. HP Compaq Presario V6000 Wifi antenna card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the connection cable, remove the two screws that hold the wireless card to the motherboard.
    • Then gently remove card without causing any damage to card itself or surrounding parts.
Hunter Griffin
crwdns2935283:010/11/16crwdne2935283:0
104 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 38-4, Bennett Fall 2016 crwdns2935289:0Texas Tech, Team 38-4, Bennett Fall 2016crwdne2935289:0
TTU-BENNETT-F16S38G4
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 780
