HP Compaq C700 Touchpad Replacement
    1. HP Compaq C700 Touchpad Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
      • Turn off computer by pressing and holding the power button.
    2. HP Compaq C700 Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq C700 Touchpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq C700 Touchpad Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
      • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
    3. HP Compaq C700 Touchpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently lift up and remove the keyboard.
    1. HP Compaq C700 Touchpad Replacement, Touchpad: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the twenty 3 mm Phillips head screws.
      • Unscrew them using the PH0 screwdriver.
    2. HP Compaq C700 Touchpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the hard drive by pulling on the plastic tab and lifting upward.
    3. HP Compaq C700 Touchpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate and unscrew the two Phillips head 3 mm screws on the wireless card.
    4. HP Compaq C700 Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unhook the two wires connecting to the wireless card by gently pulling them out.
    5. HP Compaq C700 Touchpad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently lift and pull out the card.
    6. HP Compaq C700 Touchpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the power button connector wire.
      • Using the tweezers, unhook the wire.
    7. HP Compaq C700 Touchpad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq C700 Touchpad Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Press and hold the lock to pop the panel piece above the keyboard and pull up to remove it.
    8. HP Compaq C700 Touchpad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq C700 Touchpad Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq C700 Touchpad Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unplug the remaining wires using the tweezers.
    9. HP Compaq C700 Touchpad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently pull out the three wires.
    10. HP Compaq C700 Touchpad Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq C700 Touchpad Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate the four 3 mm Phillips head screws.
    11. HP Compaq C700 Touchpad Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unhook the display connector wire.
    12. HP Compaq C700 Touchpad Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently disconnect the display by pulling it upwards.
    13. HP Compaq C700 Touchpad Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the disk drive on the side of the device.
      • Remove it by pulling it all the way out.
    14. HP Compaq C700 Touchpad Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the PH0 screwdriver to remove the two 3 mm Phillips head screws in the disk drive port.
    15. HP Compaq C700 Touchpad Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the touchpad connection using the tweezers.
    16. HP Compaq C700 Touchpad Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the plastic opening tool to pry up all sides of the device cover.
    17. HP Compaq C700 Touchpad Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the cover by lifting it.
    18. HP Compaq C700 Touchpad Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the PH0 screwdriver to remove the six 1 mm Phillips head screws surrounding the touchpad
    19. HP Compaq C700 Touchpad Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the tweezers to remove the touchpad wire connection.
    20. HP Compaq C700 Touchpad Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq C700 Touchpad Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the plastic opening tool to pry up the touchpad cover.
      • Lift and remove the touchpad cover.
    21. HP Compaq C700 Touchpad Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the blow dryer to melt the adhesive around the edge of the touchpad.
      • The touchpad is now free to be removed.
Taylor Johansen
crwdns2935283:010/20/16crwdne2935283:0
711 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-6, Martin Fall 2016 crwdns2935289:0UMass Dartmouth, Team 5-6, Martin Fall 2016crwdne2935289:0
UMASSD-MARTIN-F16S5G6
crwdns2935297:071crwdne2935297:0
I need Compaq laptop c700 Touch pad
So how can I get it?
Suraj Verma - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 70
crwdns2942667:0crwdne2942667:0 1,806
