HP Compaq C700 Fan Replacement
  1. HP Compaq C700 Fan Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq C700 Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq C700 Fan Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
  3. HP Compaq C700 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift up and remove the keyboard.
  4. HP Compaq C700 Fan Replacement, Fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop over so that you see the bottom.
    • Locate the twenty 3 mm Phillips head screws.
    • Unscrew them using the PH0 screwdriver
  5. HP Compaq C700 Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After unscrewing the 3 mm screws, remove the hard drive covering by lifting upward.
  6. HP Compaq C700 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hard drive by pulling on the plastic tab and lifting upward.
  7. HP Compaq C700 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the covering that houses the RAM modules.
  8. HP Compaq C700 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and unscrew the two Phillips head 3 mm screws on the wireless card.
  9. HP Compaq C700 Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unhook the two wires connecting to the wireless card by gently pulling them out.
  10. HP Compaq C700 Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift and pull out the card.
  11. HP Compaq C700 Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the power button connector wire. (This can be found where the keyboard sits.)
    • Using the tweezers, unhook the wire.
  12. HP Compaq C700 Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq C700 Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press and hold the lock to pop the panel piece above the keyboard and pull up to remove it.
  13. HP Compaq C700 Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq C700 Fan Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the remaining wires using the tweezers.
  14. HP Compaq C700 Fan Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull out the three wires.
  15. HP Compaq C700 Fan Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq C700 Fan Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the four 3 mm Phillips head screws.
    • Unscrew them using the PH0 screwdriver.
  16. HP Compaq C700 Fan Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unhook the display connector wire.
  17. HP Compaq C700 Fan Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently disconnect the display by pulling it upwards.
  18. HP Compaq C700 Fan Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the disk drive on the side of the device.
    • Remove it by pulling it all the way out.
  19. HP Compaq C700 Fan Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the PH0 screwdriver to remove the two 3 mm Phillips head screws in the disk drive port.
  20. HP Compaq C700 Fan Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and unplug the touchpad connection using the tweezers.
  21. HP Compaq C700 Fan Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq C700 Fan Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq C700 Fan Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Opening tool, gently pry up the cover and remove it.
  22. HP Compaq C700 Fan Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the fan wire connection using the tweezers.
  23. HP Compaq C700 Fan Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the 3 mm Phillips head screw.
    • Unscrew it using the PH0 screwdriver.
  24. HP Compaq C700 Fan Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq C700 Fan Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the opening tool, gently pry up and remove the fan.
Taylor Johansen
crwdns2935283:010/20/16crwdne2935283:0
690 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-6, Martin Fall 2016 crwdns2935289:0UMass Dartmouth, Team 5-6, Martin Fall 2016crwdne2935289:0
UMASSD-MARTIN-F16S5G6
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,408
