HP Compaq C700 Fan Replacement
crwdns2869540:0crwdne2869540:0: 2031
6
29
97
2,031
crwdns2955950:0crwdne2955950:0: 1
crwdns2960002:01crwdne2960002:0.
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: crwdns2931289:01crwdne2931289:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
To remove the fan, first the keyboard must be removed as well as other components such as the display.
    1. HP Compaq C700 Fan Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
      • Turn off computer by pressing and holding the power button.
    2. HP Compaq C700 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq C700 Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq C700 Fan Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
      • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
    3. HP Compaq C700 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently lift up and remove the keyboard.
    1. HP Compaq C700 Fan Replacement, Fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the laptop over so that you see the bottom.
      • Locate the twenty 3 mm Phillips head screws.
      • Unscrew them using the PH0 screwdriver
    2. HP Compaq C700 Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • After unscrewing the 3 mm screws, remove the hard drive covering by lifting upward.
    3. HP Compaq C700 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the hard drive by pulling on the plastic tab and lifting upward.
    4. HP Compaq C700 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the covering that houses the RAM modules.
    5. HP Compaq C700 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate and unscrew the two Phillips head 3 mm screws on the wireless card.
    6. HP Compaq C700 Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unhook the two wires connecting to the wireless card by gently pulling them out.
    7. HP Compaq C700 Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently lift and pull out the card.
    8. HP Compaq C700 Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the power button connector wire. (This can be found where the keyboard sits.)
      • Using the tweezers, unhook the wire.
    9. HP Compaq C700 Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq C700 Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Press and hold the lock to pop the panel piece above the keyboard and pull up to remove it.
    10. HP Compaq C700 Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq C700 Fan Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unplug the remaining wires using the tweezers.
    11. HP Compaq C700 Fan Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently pull out the three wires.
    12. HP Compaq C700 Fan Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq C700 Fan Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate the four 3 mm Phillips head screws.
      • Unscrew them using the PH0 screwdriver.
    13. HP Compaq C700 Fan Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unhook the display connector wire.
    14. HP Compaq C700 Fan Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently disconnect the display by pulling it upwards.
    15. HP Compaq C700 Fan Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the disk drive on the side of the device.
      • Remove it by pulling it all the way out.
    16. HP Compaq C700 Fan Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the PH0 screwdriver to remove the two 3 mm Phillips head screws in the disk drive port.
    17. HP Compaq C700 Fan Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate and unplug the touchpad connection using the tweezers.
    18. HP Compaq C700 Fan Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq C700 Fan Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq C700 Fan Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using the Opening tool, gently pry up the cover and remove it.
    19. HP Compaq C700 Fan Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unplug the fan wire connection using the tweezers.
    20. HP Compaq C700 Fan Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the 3 mm Phillips head screw.
      • Unscrew it using the PH0 screwdriver.
    21. HP Compaq C700 Fan Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq C700 Fan Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the opening tool, gently pry up and remove the fan.
Taylor Johansen
crwdns2935283:010/20/16crwdne2935283:0
720 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-6, Martin Fall 2016 crwdns2935289:0UMass Dartmouth, Team 5-6, Martin Fall 2016crwdne2935289:0
UMASSD-MARTIN-F16S5G6
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 97
crwdns2959996:0crwdne2959996:0 2,031
