HP Compaq 6710b Power Button Panel Replacement
  1. HP Compaq 6710b Power Button Panel Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq 6710b Power Button Panel Replacement, Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq 6710b Power Button Panel Replacement, Keyboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
  2. HP Compaq 6710b Power Button Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
  3. HP Compaq 6710b Power Button Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq 6710b Power Button Panel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
  4. HP Compaq 6710b Power Button Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
  5. HP Compaq 6710b Power Button Panel Replacement, Power Button Panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put a finger under each side of the plastic lock on the ribbon cable and pull up.
  6. HP Compaq 6710b Power Button Panel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq 6710b Power Button Panel Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq 6710b Power Button Panel Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a flathead screwdriver, get under each plastic hinge cover until they pop.
    • Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
Khulan Orgil
crwdns2935283:004/14/15crwdne2935283:0
1,171 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-2, Maness Spring 2015 crwdns2935289:0Cal Poly, Team 4-2, Maness Spring 2015crwdne2935289:0
CPSU-MANESS-S15S4G2
crwdns2942667:0crwdne2942667:0 3,532
