HP Compaq 6510b Fan Replacement
  1. HP Compaq 6510b Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq 6510b Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the computer over so the backside is facing you.
    • Using the two prongs that are located in the back, slide the further left prong and the upper right prong to the left as indicated in the image.
    • Slide the battery out.
  2. HP Compaq 6510b Fan Replacement, RAM: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq 6510b Fan Replacement, RAM: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip your device over.
    • In the center of the bottom of the laptop, there is a panel with two screws. Using the JIS #1 screw head unscrew both.
    • Lift the panel.
  3. HP Compaq 6510b Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq 6510b Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq 6510b Fan Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The RAM is held down by two prongs. Gently pull them until the RAM pops out of place.
    • Lift the RAM out of place.
  4. HP Compaq 6510b Fan Replacement, Fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Look for tabs in between esc and f1, f4 and f5, f8 and f9, f12 and scroll.
    • Pull these tabs towards you.
  5. HP Compaq 6510b Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq 6510b Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over and on the back of the center of the keyboard there is a screw with a rectangle beside it that looks like a keyboard. Remove this Phillips 5mm screw and another similar screw in the back top left of the keyboard.
    • Then carefully lift the keyboard out of place with your fingernails or a plastic opening tool.
  6. HP Compaq 6510b Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq 6510b Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq 6510b Fan Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There will be a metallic film attached to the keyboard from the motherboard. A black latch runs along the film keeping it in place. Lift the latch and detach the film; remove it to fully remove the keyboard.
  7. HP Compaq 6510b Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Compaq 6510b Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Compaq 6510b Fan Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully undo the white film the same way you took out the metallic film
    • Once this film is removed the bar with the power button and media tools above the keyboard will pop out of place using a spudger.
  8. HP Compaq 6510b Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq 6510b Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Underneath, a metal clamp will be revealed with two Torx Security T7 17mm screws. Unscrew these.
    • Carefully lift the cable out of place that is to the right of it.
  9. HP Compaq 6510b Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq 6510b Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew these two JIS #1 5mm screws on the fan.
    • Carefully unplug the fans' wires.
    • Remove the fan and put in new one.
Joseph Noudom
crwdns2935283:003/01/18crwdne2935283:0
587 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S2-G5, Simcock Spring 2018 crwdns2935289:0UMass Dartmouth, Team S2-G5, Simcock Spring 2018crwdne2935289:0
UMASSD-SIMCOCK-S18S2G5
Many Thanks!
BTW, my German keyboard was held by a 3rd screw. In step 3, one needs to remove the remaining screw next to the WIFI module as well.
Torsten Spengler - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 1,519
