HP Compaq 2510p Power/audio bar Replacement
  1. HP Compaq 2510p Power/audio bar Replacement, Power/audio bar: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the 4 screws in the four corners of the laptop screen.
    • The screws may be hidden underneath a small rubber pad.
    • Be sure to ground yourself and tools before working near electronics.
  2. HP Compaq 2510p Power/audio bar Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Flathead screwdriver to remove the 4 rubber covers over the 4 screws referenced in step 1.
  3. HP Compaq 2510p Power/audio bar Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the rubber has been removed a screw will be revealed. Remove each of the four screws with your Philips head screwdriver.
  4. HP Compaq 2510p Power/audio bar Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert your spudger along the top of the screen, separating the plastic cover and the screen
  5. HP Compaq 2510p Power/audio bar Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue running your Flathead along the top of the screen until the top is completely separated.
  6. HP Compaq 2510p Power/audio bar Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq 2510p Power/audio bar Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the plastic covering of the screen towards the keyboard, exposing the inner workings of the screen.
  7. HP Compaq 2510p Power/audio bar Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the hinges at the bottom left, and right of the screen
  8. HP Compaq 2510p Power/audio bar Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Compaq 2510p Power/audio bar Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the Power/Audio bar from the hinge by gently pulling.
  9. HP Compaq 2510p Power/audio bar Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the Power/Audio bar over exposing the ribbon wire and its connection to the Power/Audio bar.
  10. HP Compaq 2510p Power/audio bar Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the ribbon wire by gently pulling the wire from its socket.
    • The wire will be separated and the bar is free.
    • Be gentle as you pull.
Derek Kohansky
crwdns2935283:010/26/16crwdne2935283:0
297 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 crwdns2935289:0UMass Dartmouth, Team 3-8, Isaacson Fall 2016crwdne2935289:0
UMASSD-ISAACSON-F16S3G8
crwdns2942667:0crwdne2942667:0 483
