HP Color LaserJet Pro MFP M277dw Power Module Replacement
  1. HP Color LaserJet Pro MFP M277dw Power Module  Replacement, Power Module: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Color LaserJet Pro MFP M277dw Power Module  Replacement, Power Module: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Color LaserJet Pro MFP M277dw Power Module  Replacement, Power Module: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open and lower the back panel by pulling it down.
    • Remove one Phillips #2 10 mm screw.
  2. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to remove the right side panel of the printer.
    • Flipping the printer on its side, with the right side facing up, will make it easier to remove.
  3. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two Phillips #2 12mm screws.
    • Remove four different pin connectors that attach to the power module located at the bottom.
    • Removing the white connector is made easier with assistance of a spudger/flat tip that loosens the clamp.
  4. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two Phillips #2 10mm from the left (front) and right (back) side that attach the power module to the printer.
  5. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slowly lift the power module from the printer using both hands.
Lyndon Fresnido
crwdns2935283:010/08/18crwdne2935283:0
205 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S4-G2, White Fall 2018 crwdns2935289:0Cal Poly, Team S4-G2, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S4G2
crwdns2935297:011crwdne2935297:0
Hello, wäre can i buy the power supply? Thank you
Jakob Hetzendorfer - crwdns2934203:0crwdne2934203:0
Thanks a lot - also works for model M281fdw
patrik maurer - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 65
crwdns2942667:0crwdne2942667:0 5,231
