This guide will help you replace your power module in a HP Color Laser Jet Pro MFP M277dw.
Open and lower the back panel by pulling it down.
Remove one Phillips #2 10 mm screw.
Use the plastic opening tool to remove the right side panel of the printer.
Remove two Phillips #2 12mm screws.
Remove four different pin connectors that attach to the power module located at the bottom.
Remove two Phillips #2 10mm from the left (front) and right (back) side that attach the power module to the printer.
Slowly lift the power module from the printer using both hands.
Hello, wäre can i buy the power supply? Thank you
Thanks a lot - also works for model M281fdw
