This is a guide to replacing the display on an HP Color LaserJet Pro MFP M277dw. You should not need any special equipment or skills to perform this replacement.
Lift up the top of the printer by pulling up on it.
Remove one Phillips #2 15mm screw.
Use the plastic opening tool to remove the top of the display component.
The cable connecting the display to the motherboard should be visible.
Lower the back panel by pulling it down.
Remove one Phillips #2 10mm screw.
Use the plastic opening tool to remove the left side panel.
Unplug the display from pink cable from the circuit board.
crwdns2935229:05crwdne2935229:0
crwdns2947412:08crwdne2947412:0
where do you get a new screen
Would like to know too where to get a new screen
“Connecting a new display will require you to feed the cable through the printer”
Well, it’s actually not too complicated, you don’t need to take any additional parts to do it. Just take out the display (also need to unscrew two black screws inside, first and then grounding cable) and pull the cable out (do it a bit harder as it’s tight), and then when you change the display, feed the cable through by using different path.
In terms of finding the display, it’s not easy, as hp doesn’t sell it. You are may be lucky to find it on eBay…
looked on ebay could not find maybe you have another place
where we can get the new display could you advise.
