HP Chromebox J5N50UT WLAN Module Replacement
  1. HP Chromebox J5N50UT WLAN Module Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before removing the bottom cover, ensure that your computer is powered down and ensure that all external devices are disconnected. If you are unsure whether the computer is off or in hibernation mode, turn the computer on, then shut it down through the operating system.
    • Position the device upside-down on a flat, level surface with the USB ports facing you.
    both for the cover replacement and shield replacement
    Ian Stoffel - crwdns2934203:0crwdne2934203:0
    For the hard drive replacement, a longer times should be indicated. for the WLAN replacement 15 minutes is indicated, but for the hard drive replacement, which can only be done after the WLAN replacement, the time is listed as 10 minutes.
  2. HP Chromebox J5N50UT WLAN Module Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your metal spudger, lift and remove the 4 rubber “feet” from each corner.
  3. HP Chromebox J5N50UT WLAN Module Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your Phillips head screwdriver, remove the four Phillips M2.5×4.0 screws that secure the bottom cover to the computer. In this step the usage of the magnetic mat will be helpful to keep up with the screws.
  4. HP Chromebox J5N50UT WLAN Module Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the flat end of your metal spudger under the bottom cover near the USB ports, then pry the bottom cover off the computer.
  5. HP Chromebox J5N50UT WLAN Module Replacement, Bottom Shield: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the two pieces of mylar tape from the bracket.
    Flag: Confusing Text
    in steps 5 and 6 it seems the bottom shield is called a bracket, so by using 2 different names it’s making it seem like we’re missing a piece/part
  6. HP Chromebox J5N50UT WLAN Module Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your Phillips #1 screwdriver, remove the four Phillips M2.5×4.0 screws that hold the shield in place.
  7. HP Chromebox J5N50UT WLAN Module Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert your spudger into the gap between the bottom shield and the ports and gently pry to lift and remove the shield.
    another picture of where to insert the spudger may be helpful. which ports are you talking about?
    Flag: Needs More Images
    Ian Stoffel -
    Flag: Missing Details
    a note step on paying attention to how the shield is positioned before removing it may make reassembly easier
    Ian Stoffel -
  8. HP Chromebox J5N50UT WLAN Module Replacement, WLAN Module: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebox J5N50UT WLAN Module Replacement, WLAN Module: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the white and black antenna cables from the module.
    Flag: Markup Mishap
    iFixit has in their Milestone 3 instructions to not use arrows. we recommend either a box over each connector or a rectangular box over the 2 instead
  9. HP Chromebox J5N50UT WLAN Module Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebox J5N50UT WLAN Module Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebox J5N50UT WLAN Module Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your Phillips #1 screwdriver, remove the M2.0×3.0 screw from the upper left corner of the module.
    • Once the screw has been removed, the module will tilt up.
    Flag: Needs Better Images
    we don’t think picture 2 is needed at all.
    picture 3 doesn’t really show how the module has popped up. the angle is wrong to make it obvious
  10. HP Chromebox J5N50UT WLAN Module Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebox J5N50UT WLAN Module Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the WLAN module by pulling it away from the slot at an angle.
Ashley Marvin
crwdns2935283:009/06/18crwdne2935283:0
685 crwdns2915208:0crwdne2915208:0
Ohio State, Team S1-G3, Whitney Fall 2018 crwdns2935289:0Ohio State, Team S1-G3, Whitney Fall 2018crwdne2935289:0
OSU-WHITNEY-F18S1G3
Please indicate brand/model/type of WLAN card, so we can know if we’re replacing with same/better upgrade.
When Ze - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 482
