HP Chromebox J5N50UT Bottom Cover Replacement
  1. HP Chromebox J5N50UT Bottom Cover Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before removing the bottom cover, ensure that your computer is powered down and ensure that all external devices are disconnected. If you are unsure whether the computer is off or in hibernation mode, turn the computer on, then shut it down through the operating system.
    • Position the device upside-down on a flat, level surface with the USB ports facing you.
    both for the cover replacement and shield replacement
    Ian Stoffel - crwdns2934203:0crwdne2934203:0
    For the hard drive replacement, a longer times should be indicated. for the WLAN replacement 15 minutes is indicated, but for the hard drive replacement, which can only be done after the WLAN replacement, the time is listed as 10 minutes.
  2. HP Chromebox J5N50UT Bottom Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your metal spudger, lift and remove the 4 rubber “feet” from each corner.
  3. HP Chromebox J5N50UT Bottom Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your Phillips head screwdriver, remove the four Phillips M2.5×4.0 screws that secure the bottom cover to the computer. In this step the usage of the magnetic mat will be helpful to keep up with the screws.
  4. HP Chromebox J5N50UT Bottom Cover Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the flat end of your metal spudger under the bottom cover near the USB ports, then pry the bottom cover off the computer.
Ashley Marvin
crwdns2935283:009/06/18crwdne2935283:0
685 crwdns2915208:0crwdne2915208:0
Ohio State, Team S1-G3, Whitney Fall 2018 crwdns2935289:0Ohio State, Team S1-G3, Whitney Fall 2018crwdne2935289:0
OSU-WHITNEY-F18S1G3
Can you explain how/where the integrated VESA mount is?
Is the mounting screw holes under the rubber feet, like other chromeboxes, from other makers?
When Ze - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 642
