HP Chromebook x360 14c-ca0053 Fan Replacement
  1. HP Chromebook x360 14c-ca0053 Fan Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook x360 14c-ca0053 Fan Replacement, Lower Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to apply light pressure on the outer sides of the 2 small screw covers located near the bottom of the device.
    • Rotate the covers until they pop up out of the screw socket enough to remove them with tweezers.
  2. HP Chromebook x360 14c-ca0053 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook x360 14c-ca0053 Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the two 3.5 mm screws.
  3. HP Chromebook x360 14c-ca0053 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook x360 14c-ca0053 Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook x360 14c-ca0053 Fan Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to peel back the feet on the top and bottom of the Chromebook to reveal four additional screws.
  4. HP Chromebook x360 14c-ca0053 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook x360 14c-ca0053 Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the 4 7 mm screws located at each corner of the device under the grips.
  5. HP Chromebook x360 14c-ca0053 Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook x360 14c-ca0053 Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook x360 14c-ca0053 Fan Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick between lower case and chassis.
    • Separate the lower case from the frame by sliding the opening pick along the perimeter until the case releases.
  6. HP Chromebook x360 14c-ca0053 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the lower case up and off.
  7. HP Chromebook x360 14c-ca0053 Fan Replacement, Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook x360 14c-ca0053 Fan Replacement, Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook x360 14c-ca0053 Fan Replacement, Battery: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the tweezers wide enough to fit on each side of motherboard battery connection.
    • Pull the connector directly out of its socket.
  8. HP Chromebook x360 14c-ca0053 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook x360 14c-ca0053 Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the five 3 mm screws that secure the battery.
    • These screws are labeled 1-5.
  9. HP Chromebook x360 14c-ca0053 Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery up and out.
    • Be careful as to not puncture or damage the battery.
  10. HP Chromebook x360 14c-ca0053 Fan Replacement, Heat Sink: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook x360 14c-ca0053 Fan Replacement, Heat Sink: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the four 3 mm screws that secure the heatsink.
  11. HP Chromebook x360 14c-ca0053 Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the heat sink.
    • Add thermal paste to the new heat sink before replacement.
  12. HP Chromebook x360 14c-ca0053 Fan Replacement, Fan: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook x360 14c-ca0053 Fan Replacement, Fan: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook x360 14c-ca0053 Fan Replacement, Fan: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws that secure the fan.
  13. HP Chromebook x360 14c-ca0053 Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook x360 14c-ca0053 Fan Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook x360 14c-ca0053 Fan Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the tweezers gently underneath the fan's motherboard connection and lift up to disconnect it.
  14. HP Chromebook x360 14c-ca0053 Fan Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the fan up and out of the chassis.
Cassidy
crwdns2935283:009/18/23crwdne2935283:0
691 crwdns2915208:0crwdne2915208:0
University of Colorado Denver, Team 1-2, Campeau Fall 2023 crwdns2935289:0University of Colorado Denver, Team 1-2, Campeau Fall 2023crwdne2935289:0
UCDENVER-CAMPEAU-F23S1G2
crwdns2931471:06crwdne2931471:0
crwdns2942667:0crwdne2942667:0 174
