HP Chromebook x360 11-ae010nr Internet Card Replacement
  1. HP Chromebook x360 11-ae010nr Internet Card Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook x360 11-ae010nr Internet Card Replacement, Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device upside down so that the screws are visible.
    • Loosen two captive Phillips #1 screws from the center of the device.
    • Remove three 9.3 mm Phillips #1 screws from the joint side of the device.
    • Remove four 6.1 mm Phillips #1 screws from the opening side of the device.
  2. HP Chromebook x360 11-ae010nr Internet Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook x360 11-ae010nr Internet Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook x360 11-ae010nr Internet Card Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an iFixit opening tool between the edge of the keyboard assembly and the base of the device.
    • Push down on the handle of the opening tool to create an opening between the keyboard assembly and the base of the device.
    • Move the opening tool around the device, popping open the clips with force when necessary, until the keyboard assembly is fully lifted from the base of the device.
  3. HP Chromebook x360 11-ae010nr Internet Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook x360 11-ae010nr Internet Card Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the keyboard assembly and the case.
    • Two cables connect the keyboard to the device, so take caution to not damage these cables.
    • Flip the black plastic tab where the wider cable meets the main board using the tip of a spudger or a fingernail.
    • Remove the cable with curved needle nose pliers or your fingers.
  4. HP Chromebook x360 11-ae010nr Internet Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook x360 11-ae010nr Internet Card Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the white plastic tab where the thinner cable meets the main board using the tip of a spudger or a fingernail.
    • Separate the keyboard from the laptop.
  5. HP Chromebook x360 11-ae010nr Internet Card Replacement, Internet Card: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook x360 11-ae010nr Internet Card Replacement, Internet Card: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook x360 11-ae010nr Internet Card Replacement, Internet Card: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two numbered cords connected to the internet card using curved tweezers or your fingers.
  6. HP Chromebook x360 11-ae010nr Internet Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 3.5 mm Phillips #1 screw from the internet card.
  7. HP Chromebook x360 11-ae010nr Internet Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook x360 11-ae010nr Internet Card Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel up the plastic film on the edge of the internet card using curved tweezers or your fingers.
    • Remove the internet card by moving it to the left.
Chloe Burdzel
crwdns2935283:010/27/19crwdne2935283:0
300 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G9, O'Connell Fall 2019 crwdns2935289:0UMass Dartmouth, Team S1-G9, O'Connell Fall 2019crwdne2935289:0
UMASSD-O'CONNELL-F19S1G9
crwdns2942667:0crwdne2942667:0 695
