HP Chromebook 14a-nf009nr Display Cable Replacement
  1. HP Chromebook 14a-nf009nr Display Cable Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14a-nf009nr Display Cable Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 13 mm screws with a Phillips #00 screwdriver.
    • Remove the two 6.6 mm screws with the Phillips #00 screwdriver.
  2. HP Chromebook 14a-nf009nr Display Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14a-nf009nr Display Cable Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide an opening tool along the edges of the back cover to remove it, revealing the components of the laptop underneath.
  3. HP Chromebook 14a-nf009nr Display Cable Replacement, Screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14a-nf009nr Display Cable Replacement, Screen: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the four 5 mm screws securing the hinges.
  4. HP Chromebook 14a-nf009nr Display Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14a-nf009nr Display Cable Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the six 2.5 mm screws with a Phillips #1 screwdriver to remove the motherboard's cover.
  5. HP Chromebook 14a-nf009nr Display Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the SSD wires from the SSD card.
    • Be gentle. The wire attachment is delicate.
  6. HP Chromebook 14a-nf009nr Display Cable Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14a-nf009nr Display Cable Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the webcam cable from the motherboard.
    • Some cables will have lock bars, which you will need to lift with care to unlock.
  7. HP Chromebook 14a-nf009nr Display Cable Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14a-nf009nr Display Cable Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #1 screwdriver to remove the six 5 mm screws securing the hinges.
    • Use the Phillips #1 screwdriver to remove the 2.5 mm screws securing the hinges.
  8. HP Chromebook 14a-nf009nr Display Cable Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14a-nf009nr Display Cable Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the fabric tape to reveal the display cable attachment.
    • Lift the lock bar to remove the display cable.
    • This will detach the screen from the keyboard.
  9. HP Chromebook 14a-nf009nr Display Cable Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the iFixit opening tool to remove the display bezel screen frame.
    • Be gentle so as to not crack the screen.
  10. HP Chromebook 14a-nf009nr Display Cable Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14a-nf009nr Display Cable Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the stretch release tape until it is completely removed from the display panel.
    • Lift the left hinge to remove the stretch-release tape on the left side of the display panel using the same method.
    • Slightly lift the top of the right hinge to allow access to the stretch-release tape.
  11. HP Chromebook 14a-nf009nr Display Cable Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the screen to remove it.
  12. HP Chromebook 14a-nf009nr Display Cable Replacement, Display Cable: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook 14a-nf009nr Display Cable Replacement, Display Cable: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook 14a-nf009nr Display Cable Replacement, Display Cable: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back the tape and unplug the LCD cable to separate it from the screen.
Grace Hall
crwdns2935283:001/30/25crwdne2935283:0
775 crwdns2915208:0crwdne2915208:0
Carson-Newman University, Team 1-1, Sobiech Spring 2025 crwdns2935289:0Carson-Newman University, Team 1-1, Sobiech Spring 2025crwdne2935289:0
CNU-SOBIECH-S25S1G1
crwdns2942667:0crwdne2942667:0 107
