HP Chromebook 14a-ne0013dx Speakers Replacement
  1. HP Chromebook 14a-ne0013dx Speakers Replacement, Keyboard Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 8 mm screws from the bottom panel of the laptop using a Phillips #0 screwdriver.
    • Remove six 6 mm screws from the bottom panel of the laptop using a Phillips #0 screwdriver.
  2. HP Chromebook 14a-ne0013dx Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14a-ne0013dx Speakers Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device over so it is right side up and open it.
    • Use a Jimmy to gently pry between the keyboard and case.
    • Lift the top panel gently. Once loose, ribbon cables inside will need to be detached.
    • Pry gently to pop open the plastic tabs holding the top panel in. A clicking noise will occur during this step
    • Continue prying, moving around all sides of the panel until it is loose.
    • Carefully lift the top panel from the device body.
  3. HP Chromebook 14a-ne0013dx Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14a-ne0013dx Speakers Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Removal of ribbon cables may require lifting or peeling tape.
    • Lift the top piece of the display cable's housing until it is loose. Gently pull it free.
    • Lift the top piece of the touchpad cable's housing until it is loose. Gently pull it free.
    • With the cables detached, lift the front panel away from the device.
  4. HP Chromebook 14a-ne0013dx Speakers Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14a-ne0013dx Speakers Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel the tape off of the cable connecting the battery to the motherboard.
    • Grasp the connector and tug until loose.
  5. HP Chromebook 14a-ne0013dx Speakers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook 14a-ne0013dx Speakers Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook 14a-ne0013dx Speakers Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 3 mm screws from the battery casing using a Phillips #0 screwdriver.
    • Gently peel the tape pieces connecting the battery to cables on the bottom panel.
    • Lift the top panel off, then lift the battery out of the casing.
  6. HP Chromebook 14a-ne0013dx Speakers Replacement, Speakers: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook 14a-ne0013dx Speakers Replacement, Speakers: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook 14a-ne0013dx Speakers Replacement, Speakers: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 3 mm screws with a Phillips #0 screwdriver.
  7. HP Chromebook 14a-ne0013dx Speakers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the wire connecting the speaker to the motherboard. Lift up the tape that is blocking the wire from the motherboard.
    • Gently grab and pull the wires out of the connecting socket to detach the speaker bar fully.
  8. HP Chromebook 14a-ne0013dx Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the speaker bar out of the device.
Evan Shelley
crwdns2935283:001/24/25crwdne2935283:0
716 crwdns2915208:0crwdne2915208:0
Colorado Mesa University, Team 1-2, Kinney Spring 2025 crwdns2935289:0Colorado Mesa University, Team 1-2, Kinney Spring 2025crwdne2935289:0
CMU-KINNEY-S25S1G2
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 76
