You are able to disassemble your laptop and, as a last result, purchase a new one, through a variety of different sellers. One of the most popular would be Amazon or HP themselves. The battery is an integrated 59Wh battery and it's expected use time. 5 hours
Turn the Chromebook upside down so that the bottom is facing upwards.
Remove the small rubber circles from all four corners.
Remove the other three rubber pads from the bottom
Proceed to unscrew all the screws.
Flip the laptop back over and open it so that the keyboard is revealed to you.
Use a plastic opening tool to pry off the keyboard. It's slightly difficult to get off, but go evenly around all four sides until it pops out.
The long, flat, black component that takes up the majority of the space is the battery.
All you are required to do is unscrew the screws attached to the battery and then gently remove the battery from the Chromebook.
