HP Chromebook 14-x010wm Battery Replacement
  1. HP Chromebook 14-x010wm Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-x010wm Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-x010wm Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the thirteen 5.7mm screws from the back of the laptop using a Phillips #00 screwdriver.
    • Remove rubber covers to reveal concealed screws, as needed.
  2. HP Chromebook 14-x010wm Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-x010wm Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-x010wm Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the laptop over carefully and open the cover.
    • Use a plastic opening tool to pry open the front edge and along the sides of the keyboard cover to separate it from the computer’s base.
    • Lift the keyboard cover from the computer’s base carefully.
  3. HP Chromebook 14-x010wm Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-x010wm Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-x010wm Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lifting the keyboard cover too much may damage the internal cables of the laptop.
    • Lift the black plastic flap, using a plastic opening tool, of the zero insertion force (ZIF) connector that holds the keyboard cable in place.
    • Disconnect the keyboard cable by slowly pulling it from the system board.
    • Lift the black plastic flap that holds the battery cable in place using a plastic opening tool.
    • Remove the battery cable by slowly pulling the plastic connector towards you.
    • Remove carefully and set aside keyboard panel.
  4. HP Chromebook 14-x010wm Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14-x010wm Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the plastic flap holding the battery cable using a plastic opening tool.
    • Disconnect the battery cable by carefully pulling it from the system board.
  5. HP Chromebook 14-x010wm Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-x010wm Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-x010wm Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the seven M2xL3.0 screws from around the battery using a Phillips #00 screwdriver.
  6. HP Chromebook 14-x010wm Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14-x010wm Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel the wire band off of the battery carefully.
    • Remove the battery by lifting slightly, then slowly pull it towards you.
Follow these instructions in reverse order to reassemble your device.
Tyler Stover
crwdns2935283:004/02/19crwdne2935283:0
137 crwdns2915208:0crwdne2915208:0
IUPUI, Team S3-G3, Harley Spring 2019 crwdns2935289:0IUPUI, Team S3-G3, Harley Spring 2019crwdne2935289:0
IUPUI-HARLEY-S19S3G3
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 410
