HP Chromebook 14-q010nr Motherboard Replacement
  1. HP Chromebook 14-q010nr Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by turning the Chromebook onto its back.
    • Remove the 15 screws with a Phillips #0 screwdriver.
    • Four screws will be located underneath the device's rubber foot pads.
    Mine did not have screws under the rubber foot pads.
    Drake Sobania - crwdns2934203:0crwdne2934203:0
  2. HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the keyboard from the base plate with an opening pick to pry it open from both sides of the keyboard.
    • Beginning from the corners closest to the computer screen may result in easier disconnection.
    There are cables connecting the keyboard to the motherboard. These need to be disconnected.
  3. HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the seven screws securing the battery.
  4. HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently disconnect the battery's motherboard connection by pinching the white attachment and pulling the plug directly out of the port.
  5. HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before removing the battery, gently lift the white ribbon cable taped to the battery.
    • Gently pull up from the back of the battery to remove it.
  6. HP Chromebook 14-q010nr Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eleven motherboard screws with a 2mm Phillips screwdriver.
  7. HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the white ribbon cable from the motherboard by lifting the black ZIF connector.
  8. HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five screws attached to the connector plate.
    • Remove the monitor connector by lifting it gently upward.
  9. HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the antenna cables on the right side of the motherboard.
    • Carefully lift the motherboard up to remove it. Use a spudger for ease.
Julian Knight
crwdns2935283:009/22/22crwdne2935283:0
159 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 3-4, Saru Jimmy Fall 2022 crwdns2935289:0University of North Texas, Team 3-4, Saru Jimmy Fall 2022crwdne2935289:0
UNT-SARU JIMMY-F22S3G4
can this version of the chrome book be updated?
Danielle Curtis - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 224
