HP Chromebook 14-q010nr Motherboard Replacement
  1. HP Chromebook 14-q010nr Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by turning the Chromebook onto its back.
    • Remove the 15 screws with a Phillips #0 screwdriver.
    • Four screws will be located underneath the device's rubber foot pads.
  2. HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the keyboard from the base plate with an opening pick to pry it open from both sides of the keyboard.
    • Beginning from the corners closest to the computer screen may result in easier disconnection.
  3. HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the seven screws securing the battery.
  4. HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently disconnect the battery's motherboard connection by pinching the white attachment and pulling the plug directly out of the port.
  5. HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before removing the battery, gently lift the white ribbon cable taped to the battery.
    • Gently pull up from the back of the battery to remove it.
  6. HP Chromebook 14-q010nr Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eleven motherboard screws with a 2mm Phillips screwdriver.
  7. HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the white ribbon cable from the motherboard by lifting the black ZIF connector.
  8. HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five screws attached to the connector plate.
    • Remove the monitor connector by lifting it gently upward.
  9. HP Chromebook 14-q010nr Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the antenna cables on the right side of the motherboard.
    • Carefully lift the motherboard up to remove it. Use a spudger for ease.
Julian Knight
crwdns2935283:009/22/22crwdne2935283:0
159 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 3-4, Saru Jimmy Fall 2022 crwdns2935289:0University of North Texas, Team 3-4, Saru Jimmy Fall 2022crwdne2935289:0
UNT-SARU JIMMY-F22S3G4
can this version of the chrome book be updated?
Danielle Curtis - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 263
