HP Chromebook 14-ca061dx Display Replacement
  1. HP Chromebook 14-ca061dx Display Replacement, Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-ca061dx Display Replacement, Display: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-ca061dx Display Replacement, Display: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the Chromebook so that the underside is facing upwards.
    • Follow along the edge with the iFixit opening tool to unhinge the display frame.
  2. HP Chromebook 14-ca061dx Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the Chromebook right side up and open it to form a 180 degree angle.
  3. HP Chromebook 14-ca061dx Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the iFixit opening tool to pry open the bezel. Start from the bottom of the screen and work your way around the sides.
    • The bottom edge of the bezel may stick because there is glue holding it together.
  4. HP Chromebook 14-ca061dx Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14-ca061dx Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use spudger or the iFixit opening tool to remove the bezel.
    • When prying, be careful not to damage or snap bezel. This is made up of very, thin plastic.
    • Pull bezel from the bottom, once all clips are detached.
    • Remove bezel.
  5. HP Chromebook 14-ca061dx Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14-ca061dx Display Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 2mm JIS #000 screws.
  6. HP Chromebook 14-ca061dx Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14-ca061dx Display Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to pull the tape back and remove the connector attached to the back of the LCD panel.
    • Be cautious when pulling back the tape—the connector/ribbon is fragile and could snap easily.
  7. HP Chromebook 14-ca061dx Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the LCD/display panel from the Chromebook frame.
Jean Arevalo
crwdns2935283:010/31/19crwdne2935283:0
778 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S2-G5, Barthe Fall 2019 crwdns2935289:0UMass Dartmouth, Team S2-G5, Barthe Fall 2019crwdne2935289:0
UMASSD-BARTHE-F19S2G5
should disconnect the laptop battery first
TJ Kleckner - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,980
