Nowadays, laptop screens can be easily damaged. The HP Chromebook 14-ca061dx screen could be physically damaged, with broken glass, or black splotches on the display, or could be defective, without any signs of physical damage. A defective screen could display resolution lines, distorted coloring, or nothing at all. If you know these problems are caused by a broken, or defective a screen, you may just need a replacement. Follow this guide to help with your screen/display replacement.
Flip the Chromebook so that the underside is facing upwards.
Follow along the edge with the iFixit opening tool to unhinge the display frame.
Flip the Chromebook right side up and open it to form a 180 degree angle.
Use the iFixit opening tool to pry open the bezel. Start from the bottom of the screen and work your way around the sides.
Use spudger or the iFixit opening tool to remove the bezel.
Pull bezel from the bottom, once all clips are detached.
Remove bezel.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to pull the tape back and remove the connector attached to the back of the LCD panel.
Remove the LCD/display panel from the Chromebook frame.
should disconnect the laptop battery first
