HP Chromebook 14-Q070NR Motherboard Replacement
  1. HP Chromebook 14-Q070NR Motherboard Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • At this point, the white caps that hide the top-most screws marked with red circles have been removed.
    • Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
    • After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
  2. HP Chromebook 14-Q070NR Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-Q070NR Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-Q070NR Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the laptop and place it upright. Remove the keyboard from the device using a plastic spudger or opening tool.
    • Carefully remove as there are ribbons attached to the keyboard that is connected to the components inside.
    • Gently lift the keyboard just enough to expose the ribbons.
  3. HP Chromebook 14-Q070NR Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-Q070NR Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-Q070NR Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the keyboard up to remove the ribbons from the circuit board.
    • To remove each individual ribbon, grab the blue portion of each ribbon and pull it towards your direction until it is fully detached.
  4. HP Chromebook 14-Q070NR Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-Q070NR Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-Q070NR Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the ribbons are detached, remove the keyboard from the device.
  5. HP Chromebook 14-Q070NR Motherboard Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove the (2) two screws at the bottom of the device.
    • Once removed, separate the screws from previous ones. They are different!
  6. HP Chromebook 14-Q070NR Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14-Q070NR Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the taped flat wire from the top of the battery.
    • Carefully pull away the connector from the top of the battery to the motherboard.
  7. HP Chromebook 14-Q070NR Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the battery and remove it from the device.
  8. HP Chromebook 14-Q070NR Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-Q070NR Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-Q070NR Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the (3) three plastic strips attached to the motherboard.
  9. HP Chromebook 14-Q070NR Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14-Q070NR Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #1 screwdriver to remove the (5) five screws.
  10. HP Chromebook 14-Q070NR Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14-Q070NR Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the blue plastic opening tool to disconnect the connectors. Remove the fan from the motherboard.
  11. HP Chromebook 14-Q070NR Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14-Q070NR Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift while using the plastic opening tool to unhinge the motherboard from the computer in an upward pattern.
    • Be very careful not to detach the motherboard to quickly or forcefully since you could damage or break it.
Jose Hernandez
crwdns2935283:010/02/17crwdne2935283:0
USF Tampa, Team S9-G5, Remmell Fall 2017 crwdns2935289:0USF Tampa, Team S9-G5, Remmell Fall 2017crwdne2935289:0
USFT-REMMELL-F17S9G5
crwdns2942667:0crwdne2942667:0 359
