This guide will require removal of 1x3mm screws.
Flip the laptop so the base of the laptop is facing you.
Using the #00 screwdriver, unscrew the 13 screws.
Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
Lift the white flap and pull the blue ribbon towards you until it is disconnected.
Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
Undo the black tape located on the bottom from the frame of the laptop.
Using fingers or the spudger, slide out the black connector indicated on the left.
Use a #00 screwdriver to remove the two screws.
Lift the black flaps and gently pull the strip out.
Set the strip aside.
Remove the screw.
Use your fingers to pull the white tab out of the black slot above the battery.
While reassembling, the chromebook powered up when I reconnected the battery. Didn’t know how I could power it down, as the keyboard was not connected at this point.
Using a spudger, remove the white and black cables from the card.
Gently pull card at a 45° angle to remove it.
Remove screw indicated by the red circle at the top of the card port.
Remove the 3 screws around the fan.
Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard.
Once the cable connecting the fan to the motherboard is revomed gently remove fan with hands.
how do I go about taking the fan off and what do I do after that?
Do I need to replace my fan?
Using your fingers or spudger, pull out the connector.
Remove all of the indicated screws.
Pull up on black strip to remove the monitor cord.
Remove the screw indicated by the red circle.
Remove the hard drive by pulling the device from the black slot.
crwdns2935229:014crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Thanks so much for your clearly , detailed and easy to follow guide, nice job!
Buenas tarde y despuesnde quitar el disco duro que se hace se cambia por otro igual o que modelo
Can you add more storage on the HP Chromebook 14 SMB about 500GB. I also want to know if the Chromebook can run Windows 10 without any problems.
Useful. Wish I would have read it B4 I started this project.
how do i upgrde my chrom browser?
