HP Chromebook 11A G8 EE Touchpad Replacement
  1. HP Chromebook 11A G8 EE Touchpad Replacement, Keyboard Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 11A G8 EE Touchpad Replacement, Keyboard Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook 11A G8 EE Touchpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook 11A G8 EE Touchpad Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Touchpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 11A G8 EE Touchpad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
  4. HP Chromebook 11A G8 EE Touchpad Replacement, Touchpad: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 11A G8 EE Touchpad Replacement, Touchpad: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, carefully disconnect the touchpad board ribbon cable from the touchpad board.
    • Using tweezers, carefully peel back the clear sheet that covers the the touchpad board screws.
  5. HP Chromebook 11A G8 EE Touchpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 11A G8 EE Touchpad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #0 screwdriver and remove the top three 1.6 mm screws from the touchpad.
    • Remove the four bottom 2 mm screws using the same Phillips #0 screwdriver.
  6. HP Chromebook 11A G8 EE Touchpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the touchpad brackets off of the alignment pins on the top cover and remove.
  7. HP Chromebook 11A G8 EE Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using tweezers, carefully lift the touchpad board off of the board to remove.
Ella Portwood
crwdns2935283:009/03/21crwdne2935283:0
711 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 2-1, Bedsole Fall 2021 crwdns2935289:0University of Alabama, Team 2-1, Bedsole Fall 2021crwdne2935289:0
UA-BEDSOLE-F21S2G1
crwdns2942667:0crwdne2942667:0 733
