HP Chromebook 11 G8 EE Bezel Replacement
  1. HP Chromebook 11 G8 EE Bezel Replacement, Keyboard & Touchpad Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
    Is it possible that the screw location diagram is incorrect? On my g8 ee it seems that the longest screw (the orange 8 mm?) Goes closest to the screen hinge and the other 4 screws are identical size (the 7mm?).
    In the diagram, the longest screw (orange) is shown as being located farthest from the screen hinge. But I've also seen a YouTube video possibly corroborate this guide's screw information, differing from the 2 G8 EE models I checked in person.
    A X - crwdns2934203:0crwdne2934203:0
  2. HP Chromebook 11 G8 EE Bezel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 11 G8 EE Bezel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Bezel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook 11 G8 EE Bezel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook 11 G8 EE Bezel Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
  4. HP Chromebook 11 G8 EE Bezel Replacement, Bezel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 11 G8 EE Bezel Replacement, Bezel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your hands, pry off the hinge cover by lifting it.
  5. HP Chromebook 11 G8 EE Bezel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook 11 G8 EE Bezel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook 11 G8 EE Bezel Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the opening tool, pry the bezel away from the top case.
    • This requires firm, constant pressure. Be careful not to break the bezel.
  6. HP Chromebook 11 G8 EE Bezel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the bezel toward you.
    • Peel it away from the screen gently.
  7. HP Chromebook 11 G8 EE Bezel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Completely remove the bezel.
Isabella Brown
crwdns2935283:010/25/22crwdne2935283:0
312 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 crwdns2935289:0UMass Dartmouth, Team 4-2, Sinclaire Fall 2022crwdne2935289:0
UMASSD-SINCLAIRE-F22S4G2
crwdns2935297:013crwdne2935297:0
you can remove the bezel without removing the keyboard
Anthony Taviana - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 597
