This guide will walk you through the replacement process of a defective or broken keyboard on your HP Chromebook 11 G4. Removing the keyboard is also the basic step to accessing all of the other internal components.
Position the closed Chromebook with the rubber pads are facing up.
Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
Pry off the rubber pads to reveal a screw under each pad.
Remove the eleven 6mm Phillips #1 screws.
Flip over the Chromebook and open it.
Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
Slide the spudger along the gap, applying downward pressure to separate the two components.
Lift the bottom of the keyboard assembly to reveal the internal components of the device.
Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
Remove the keyboard assembly by lifting it off the laptop base.
How do you remove the keyboard from the assembly though? And I wish there was a mention of the fact that the heat sink is attached to the keyboard assembly.
Kyle B - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Same question as the person above. I need to remove the keyboard from the assembly.
Stephen Mason - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
If you look up the parts you'll see that the entire top panel and keyboard are one assembly.
Nacho Biniz - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
