HP Beats Special Edition 15-p390nr WiFi Card Replacement
  1. HP Beats Special Edition 15-p390nr WiFi Card  Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Beats Special Edition 15-p390nr WiFi Card  Replacement, Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Beats Special Edition 15-p390nr WiFi Card  Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
  3. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Beats Special Edition 15-p390nr WiFi Card  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
  4. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Beats Special Edition 15-p390nr WiFi Card  Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal.
    • The shoulder caps are removable. Underneath there are 2 additional screws.
  5. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Beats Special Edition 15-p390nr WiFi Card  Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
  6. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Beats Special Edition 15-p390nr WiFi Card  Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
  7. HP Beats Special Edition 15-p390nr WiFi Card  Replacement, WiFi Card: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the keyboard panel is removed you will need to locate the WiFi card
  8. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two screws using the Phillips #0 screwdriver.
  9. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove wire connected to the back of the card by pulling it straight up.
  10. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull card away from you to remove it from the motherboard.
    • Refrain from wiggling or moving the card around, while connected to the motherboard, to prevent damage to connector pins.
Evan Rice
crwdns2935283:010/02/18crwdne2935283:0
533 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team S1-G3, Karnes Fall 2018 crwdns2935289:0Linn Benton Community College, Team S1-G3, Karnes Fall 2018crwdne2935289:0
LBCC-KARNES-F18S1G3
crwdns2942667:0crwdne2942667:0 1,390
