HP 7 Plus 1302 Battery Replacement
    1. HP 7 Plus 1302 Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
      • Device should be turned off and unplugged before starting the replacements.
    2. HP 7 Plus 1302 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 7 Plus 1302 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the plastic opening tool to push in between the front and the back of the tablet.
      • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
      • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
    3. HP 7 Plus 1302 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 7 Plus 1302 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
      • Remove the back cover.
    1. HP 7 Plus 1302 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 7 Plus 1302 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Push out the battery connector using the spudger.
      • Swing the battery connector clear of the connector socket.
    2. HP 7 Plus 1302 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the battery from the device.
To reassemble your device, follow these instructions in reverse order. Use new double sided tape to secure the new battery.
Jason
crwdns2935283:007/07/15crwdne2935283:0
IUPUI, Team 1-2, Renguette SU 2015 crwdns2935289:0IUPUI, Team 1-2, Renguette SU 2015crwdne2935289:0
IUPUI-RENGUETTE-SU15S1G2
crwdns2935297:048crwdne2935297:0
crwdns2942667:0crwdne2942667:0 2,109
