HP 7 PLUS 1301 Battery Replacement
  1. HP 7 PLUS 1301 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 7 PLUS 1301 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the device is off and not plugged in before starting.
    • Using the Torx T5 screwdriver, remove the 3mm screws on all 4 corners of the device.
  2. HP 7 PLUS 1301 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 7 PLUS 1301 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, push in between the front, then slide it around.
    • Slide the plastic opening tool all the way around the tablet to separate the back cover.
    • Be careful when trying to remove the back as the screen can be damaged with excessive force.
  3. HP 7 PLUS 1301 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 7 PLUS 1301 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
    • Remove the back cover.
  4. HP 7 PLUS 1301 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 7 PLUS 1301 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push out the connector to disconnect the battery.
    • Move the battery connector clear of the connector socket.
  5. HP 7 PLUS 1301 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the battery by sliding a plastic spudger under the battery. Use an adhesive remover if available under the battery to make it easier for the battery to come off.
Adanna Ilori
crwdns2935283:002/05/19crwdne2935283:0
301 crwdns2915208:0crwdne2915208:0
UC Davis, Team S20-G6, Lore Winter 2019 crwdns2935289:0UC Davis, Team S20-G6, Lore Winter 2019crwdne2935289:0
UCD-LORE-W19S20G6
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 885
