HP 7 1800 Motherboard Replacement
  1. HP 7 1800 Motherboard Replacement, Remove the back panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 7 1800 Motherboard Replacement, Remove the back panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Motherboard Replacement, Remove the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 7 1800 Motherboard Replacement, Remove the battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 7 1800 Motherboard Replacement, Remove the battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
  3. HP 7 1800 Motherboard Replacement, Remove the large ribbon cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 7 1800 Motherboard Replacement, Remove the large ribbon cable: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
  4. HP 7 1800 Motherboard Replacement, Remove the smaller ribbon cable: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 7 1800 Motherboard Replacement, Remove the smaller ribbon cable: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
  5. HP 7 1800 Motherboard Replacement, Unscrew the 7 silver screws from the logic board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following 7 screws:
    • Six 4.17mm Phillips #00 around the motherboard.
    • One 2.67mm Phillips #00 next to the front facing camera.
    • The 2.67mm screw circled in yellow is notably shorter than the other 6 screws circled in red.
  6. HP 7 1800 Motherboard Replacement, Unplug the front facing camera from the logic board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry the front facing camera plug up and off of the motherboard.
  7. HP 7 1800 Motherboard Replacement, Remove the logic board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the motherboard directly up.
TMD
crwdns2935283:001/21/15crwdne2935283:0
765 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-1, Brown Winter 2015 crwdns2935289:0USF Tampa, Team 4-1, Brown Winter 2015crwdne2935289:0
USFT-BROWN-W15S4G1
After replacing the motherboard, will is act as a brand new tablet upon next boot? Will the OS and everything already be installed? Or is the main memory module elsewhere in the tablet?
jakehittinger - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,036
