HP 7 1800 Display Replacement
  1. HP 7 1800 Display Replacement, Remove the back panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 7 1800 Display Replacement, Remove the back panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Display Replacement, Remove the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 7 1800 Display Replacement, Remove the battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 7 1800 Display Replacement, Remove the battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
  3. HP 7 1800 Display Replacement, Remove the large ribbon cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 7 1800 Display Replacement, Remove the large ribbon cable: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
  4. HP 7 1800 Display Replacement, Remove the smaller ribbon cable: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 7 1800 Display Replacement, Remove the smaller ribbon cable: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
  5. HP 7 1800 Display Replacement, Unscrew the 7 silver screws from the logic board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following 7 screws:
    • Six 4.17mm Phillips #00 around the motherboard.
    • One 2.67mm Phillips #00 next to the front facing camera.
    • The 2.67mm screw circled in yellow is notably shorter than the other 6 screws circled in red.
  6. HP 7 1800 Display Replacement, Unplug the front facing camera from the logic board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry the front facing camera plug up and off of the motherboard.
  7. HP 7 1800 Display Replacement, Remove the logic board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the motherboard directly up.
  8. HP 7 1800 Display Replacement, Remove the ribbon cable attached to the metal plate: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 7 1800 Display Replacement, Remove the ribbon cable attached to the metal plate: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the metal plate inside of the device, there is a ribbon cable in a loop. Flip the white tab and pull the cable out.
  9. HP 7 1800 Display Replacement, Unscrew the 7 black screws on the metal plate: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the following black screws:
    • Seven 2.82mm Phillips #00 around the metal casing.
  10. HP 7 1800 Display Replacement, Remove the metal plate: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the metal plate directly up.
  11. HP 7 1800 Display Replacement, Remove the display: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the display directly up.
crwdns2935229:05crwdne2935229:0
TMD
crwdns2935283:001/21/15crwdne2935283:0
765 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-1, Brown Winter 2015 crwdns2935289:0USF Tampa, Team 4-1, Brown Winter 2015crwdne2935289:0
USFT-BROWN-W15S4G1
I have this same tablet but I cannot find a replacement screen. Do you know where I could find one?
Karen Porter - crwdns2934203:0crwdne2934203:0
I have the same problem
akiel panchan -
crwdns2942667:0crwdne2942667:0 1,998
