HP 7 1800 Battery Replacement
  1. HP 7 1800 Battery Replacement, Remove the back panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 7 1800 Battery Replacement, Remove the back panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Battery Replacement, Remove the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 7 1800 Battery Replacement, Remove the battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 7 1800 Battery Replacement, Remove the battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
TMD
crwdns2935283:001/21/15crwdne2935283:0
792 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-1, Brown Winter 2015 crwdns2935289:0USF Tampa, Team 4-1, Brown Winter 2015crwdne2935289:0
USFT-BROWN-W15S4G1
This is the OEM Replacement Battery, 740963-001, HP Spare: 739691-001, but you can find an OEM replacement the fits and works perfectly will be the Dell Venue 7 battery -17.29Wh 4550 mAh P708 DHM0J and half the price.
Santiago - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Santiago is wrong, you cannot use the Dell battery because the connectors are different sizes. Now I am stuck with a Dell battery that does not fit and have to order the hp battery. Also you cannot de-pin the two and re-pin, the brass fitting on the wire are bigger and will not fit in the hp connector. DON NOT TRY USING THE DELL IN PLACE OF THE HP.
Glenn Wemmer - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 3,785
