Follow this guide to fix your LCD display.
Remove the 8 pads and the underlying screws
Use a thin tool to separate the lcd frame
Unhook the cover on the 2 hinges on the upper side
Remove the LCD cover with delicacy, paying attention to the wires and removing any adhesive if present.
Remove 4 lcd fixing screws on one side and 4 screws on the other
Force the back cover slightly to access the last screw on both sides
Disconnect the lcd panel connector
Gently lay the LCD panel on the keyboard.
Disconnect video display connector.
Remove the LCD panel and replace with the new one
To reassemble the device, follow these instructions in reverse order.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
what are those two things on top labeled 1 and 2 in the last picture?
Non ho capito la domanda. Grazie
Smilzo -
