HP 5406 zl Switch Chassis (J8697A) Replacement
  1. HP 5406 zl Switch Chassis (J8697A) Replacement, Identifying the modules: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 5406 zl Switch Chassis (J8697A) Replacement, Identifying the modules: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The equipment comes with two modules to install a supervisor card and 6 expansion slots for compatible modules.
    • J8726A Management Module.'
    • J8705A Module 20p 10/100/1000 + 4p SFP.
    • 'RESET' and 'CLEAR' buttons used for: 'CLEAR' Erase only the access passwords when pressed for at least 1 second. 'RESET' Restores factory default settings when pressed in a specific pattern.
    • RS232 console port; any baud rate from 2400 to 115200 (the switch automatically detects the speed) 8 data bits, 1 stop bit, no parity and flow control set to None
    • USB port
    • J4858C - HP Gigabit-SX-LC Mini-GBIC
  2. HP 5406 zl Switch Chassis (J8697A) Replacement, Removing the expansion modules: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 5406 zl Switch Chassis (J8697A) Replacement, Removing the expansion modules: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 5406 zl Switch Chassis (J8697A) Replacement, Removing the expansion modules: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The modules can be removed with the equipment turned on, with the exception of the 'Management Module'.
    • Loosen the screws, the screw contains a spring and once it is loose it will be ejected and will remain in the equipment.
    • To remove the module, pull the handles that are on the bottom of the module.
  3. HP 5406 zl Switch Chassis (J8697A) Replacement, Removing the Managment Module: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 5406 zl Switch Chassis (J8697A) Replacement, Removing the Managment Module: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 5406 zl Switch Chassis (J8697A) Replacement, Removing the Managment Module: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Do not remove while the equipment is on
    • Following the same procedure above, loosen the screws and pull the levers of the module to remove it.
    • RAM Memory
    • Flash card
crwdns2934873:0crwdne2934873:0
es en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Eneider Colina
crwdns2935283:009/20/13crwdne2935283:0
2 370 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 2,378
