HP 255 G8 Hard Drive Replacement
  1. HP 255 G8 Hard Drive Replacement, Hard drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 255 G8 Hard Drive Replacement, Hard drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Ensure that your laptop is powered off and it is disconnected from all peripherals and the charger.
    • Flip your laptop over so the bottom case is facing up.
    • Use a spudger to remove the two rubber strips covering the screws.
    • Keep the screw covers to replace them after you have finished the repair.
  2. HP 255 G8 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the 10 screws securing the bottom case.
  3. HP 255 G8 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the optical drive/disk drive out to remove it.
    • If you are struggling to remove the optical drive, hold the laptop down with your right hand and continue to pull with your left.
  4. HP 255 G8 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 255 G8 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the back panel off of the laptop.
    • Use a Phillips #00 screwdriver to remove four screws securing the hard drive.
  5. HP 255 G8 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift and remove the hard drive bracket.
  6. HP 255 G8 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 255 G8 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 255 G8 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the hard drive and hold it at a 30-degree angle.
    • Detach the hard drive from the connector by sliding the hard drive to the left.
Columbus Souratha
crwdns2935283:003/05/24crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 7-12, Grodsky Spring 2024 crwdns2935289:0CSU Los Angeles, Team 7-12, Grodsky Spring 2024crwdne2935289:0
CSULA-GRODSKY-S24S7G12
crwdns2936753:030crwdne2936753:0 70
crwdns2942667:0crwdne2942667:0 805
