HP 225 G7 Memory (RAM) Replacement / Upgrade
  1. HP 225 G7 Memory (RAM) Replacement / Upgrade, Remove Rubber Legs: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 225 G7 Memory (RAM) Replacement / Upgrade, Remove Rubber Legs: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spatula to remove the long rubber leg from the bottom of the laptop.
    • Repeat the same for the second rubber on the bottom.
  2. HP 225 G7 Memory (RAM) Replacement / Upgrade, Unscrew Bottom Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 225 G7 Memory (RAM) Replacement / Upgrade, Unscrew Bottom Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew all the screws on the bottom of the laptop including the ones that were under the rubber legs.
  3. HP 225 G7 Memory (RAM) Replacement / Upgrade, Remove CD/DVD Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 225 G7 Memory (RAM) Replacement / Upgrade, Remove CD/DVD Drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 225 G7 Memory (RAM) Replacement / Upgrade, Remove CD/DVD Drive: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the CD drive outwards.
    • Then pull the CD drive out.
  4. HP 225 G7 Memory (RAM) Replacement / Upgrade, Open The Laptop: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Then, open the laptop like you normally would if you were working.
  5. HP 225 G7 Memory (RAM) Replacement / Upgrade, Insert A Pick: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully insert a guitar pick under the touchpad, and leave it on there.
  6. HP 225 G7 Memory (RAM) Replacement / Upgrade, Insert All Picks Around The Laptop: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Then, slowly insert all 6 picks all around the laptop.
    • It is best to leave the picks on while you are inserting other picks so you prevent accidentally pushing on the laptop and putting the cover back on.
  7. HP 225 G7 Memory (RAM) Replacement / Upgrade, Pry Open The Cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the picks.
    • Pull the cover and the main body of the laptop apart.
    • If you find a lot of resistance while trying to pull the bottom cover off, close the screen because the hinges often "hold" the bottom cover. If you still find a lot resistance, check for any forgotten screws. Don't apply too much force if you are having difficulty.
  8. HP 225 G7 Memory (RAM) Replacement / Upgrade, How The Laptop Should Look Like: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After prying the bottom cover off, the bottom of the laptop should look like that.
  9. HP 225 G7 Memory (RAM) Replacement / Upgrade, Locate The RAM: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the RAM dim on the upper right corner of the laptop. ("upper" when the screen hinge is facing upwards)
  10. HP 225 G7 Memory (RAM) Replacement / Upgrade, "Unlock" The RAM Dim: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 225 G7 Memory (RAM) Replacement / Upgrade, "Unlock" The RAM Dim: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to push both of the clips outwards. Then the dim should pop upwards.
  11. HP 225 G7 Memory (RAM) Replacement / Upgrade, Remove The RAM Dim: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Then, you can simply pull the RAM dim outwards, and remove it.
    • Insert the new dim in the slot.
    • Then, push downwards on the dim to lock it in place.
Stratos Thivaios
crwdns2935283:002/27/23crwdne2935283:0
1 357 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 842
