HP 225 G7 Battery Replacement
  1. HP 225 G7 Battery Replacement, Flip The Laptop Upside Down: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Firstly, flip the laptop upside down, so that you are looking at the bottom of it, and the hinge of the screen is facing away from you.
  2. HP 225 G7 Battery Replacement, Remove The Rubber "Leg": crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 225 G7 Battery Replacement, Remove The Rubber "Leg": crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the metal spuger (or another tool, just make sure its not too sharp) to remove the rubber "leg", all the way until it is completely removed.
  3. HP 225 G7 Battery Replacement, Remove The Upper Rubber "Leg": crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat for the top rubber.
  4. HP 225 G7 Battery Replacement, Unscrew: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 225 G7 Battery Replacement, Unscrew: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 225 G7 Battery Replacement, Unscrew: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew all the screws from the laptop, including the ones that were under the rubber "legs".
    • There should be 11 screws in total. (4 under the upper leg, 3 under the lower one, and 4 that were not under rubber).
  5. HP 225 G7 Battery Replacement, Start Inserting The Picks: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully insert a pick under the touchpad of the laptop.
  6. HP 225 G7 Battery Replacement, Continue Inserting Picks: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue inserting picks all the way around the laptop.
  7. HP 225 G7 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull apart the cover and the body of the laptop.
    • If you find resistance, reduce the angle of the screen hinge, since the hinge might be "clamping" the cover.
    • If you still find resistance, check for any forgotten screws on the bottom. Never apply too much pressure if there is a lot of resistance.
  8. HP 225 G7 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finally, the bottom of the laptop should look like that.
  9. HP 225 G7 Battery Replacement, Locate and unscrew the 3 screws holding the battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and unscrew the 3x Philips 1 screws that hold the battery.
  10. HP 225 G7 Battery Replacement, Remove the battery: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 225 G7 Battery Replacement, Remove the battery: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 225 G7 Battery Replacement, Remove the battery: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After unscrewing the 3 screws, pull the top side of the battery up then slide it out to remove it.
    • Fire Hazard : Always handle lithium batteries with caution.
Stratos Thivaios
crwdns2935283:002/27/23crwdne2935283:0
1.357 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 455
