HP 2000-427CL CPU Cooler Replacement
  1. HP 2000-427CL CPU Cooler Replacement, Remove battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the battery facing towards you, slide the latch to the right.
    • Grab the battery as it lifts out of the laptop.
  2. HP 2000-427CL CPU Cooler Replacement, Remove keyboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 2000-427CL CPU Cooler Replacement, Remove keyboard: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 2000-427CL CPU Cooler Replacement, Remove keyboard: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three M2.5x5 Philips screws securing the keyboard.
    • Remove the memory cover.
    • Remove the single remaining M2.5x5 Philips screw securing the keyboard.
    • Flip the laptop right side-up, and open the screen.
    • Pop each keyboard clip with a spudger, pulling up on the keyboard as you do it. Try not to pry, but rather move the clips, or else you risk damaging the palmrest.
    • Undo the keyboard connector clip, and remove the cable.
    • Remove the single screw that was hidden under the keyboard.
    • Also undo every other visible connector, that being the power button, touchpad, and touchpad button connectors.
  3. HP 2000-427CL CPU Cooler Replacement, Remove palmrest: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hard drive cover, and then remove the three screws hidden underneath it.
    • Remove the hard drive, and remove the single hidden M2.5x5 screw under it. Also remove the connector that connects the SATA connector (so many connections!) to the motherboard.
    • Remove the eight M2.5x5 Philips screws securing the palmrest.
    • Remove the two long Philips screws securing the palmrest.
    • Remove the four remaining Philips screws securing the palmrest.
    • Remove the wireless card.
    • Also remove the DC jack connector.
  4. HP 2000-427CL CPU Cooler Replacement, Remove motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all connectors from the motherboard.
    • Remove the three M2.5x5 screws from the left speaker, and remove the speaker.
    • After removing the speaker, remove the single screw securing the left hinge to the base.
    • Remove the single screw securing the motherboard to the base.
    • Lift the motherboard up and out.
  5. HP 2000-427CL CPU Cooler Replacement, Remove cooler: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four captive Philips screws securing the cooler to the motherboard. You're done!
    • Be sure to use alcohol to clean the thermal paste, and then apply new thermal paste.
Joseph Sctbunio
crwdns2935283:009/23/17crwdne2935283:0
7,578 crwdns2915208:0crwdne2915208:0
crwdns2935297:042crwdne2935297:0
Anyway you could add photos of how you can reconnect the keyboard to the motherboard with all the ribbon cables? I am having a very difficult time trying to figure out how I can reconnect them as they are very short and there is really no space to lift the keyboard high enough to get the cables slotted.
Latiron London - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 607
