HP 2000 - 2D22DX RAM Replacement
crwdns2869540:0crwdne2869540:0: 4.7K
5
23
112
4,718
crwdns2955950:0crwdne2955950:0: 1
crwdns2960002:01crwdne2960002:0.
crwdns2959984:0crwdne2959984:0: 7
crwdns2959974:07crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 5
crwdns2959982:05crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 5 - 10 crwdns2931279:0crwdne2931279:0
Directions for the removal and replacement of the RAM module in a HP 2000 - 2D22DX laptop computer. When adding more RAM, always replace the existing modules to ensure compatibility between modules.
    1. HP 2000 - 2D22DX RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 2000 - 2D22DX RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the device over and locate the battery compartment.
      • Slide the battery release latch to the left until the battery is detached from its slot.
      • A distinguishable pop will be heard when the battery is fully released.
    2. HP 2000 - 2D22DX RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 2000 - 2D22DX RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
    1. HP 2000 - 2D22DX RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 2000 - 2D22DX RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • After battery removal, the RAM compartment cover is exposed.
      • Locate the Phillips head screw seen in the second picture. It secures the RAM compartment to the plastic chassis.
      • Loosen the screw that is securing the RAM compartment with a Phillips #00 screwdriver.
      • The screw is permanently attached to the RAM compartment cover. Do not try to remove it completely.
    2. HP 2000 - 2D22DX RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 2000 - 2D22DX RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once the screw is sufficiently loosened, gently unclip the RAM compartment cover from its slots in the plastic chassis.
      • Pull the compartment door out and away from the chassis, exposing the black film covering the RAM module.
    3. HP 2000 - 2D22DX RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 2000 - 2D22DX RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 2000 - 2D22DX RAM Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Move the black plastic film to the side to locate the RAM slots.
      • Locate the metal clips holding the RAM card in place.
      • Using your fingers, push the metal clips out and away from the RAM module until the RAM module pops up at a 45 degree angle.
    4. HP 2000 - 2D22DX RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Hold the black plastic film away from the RAM slots. Grasp the edge of the RAM card and slide it out at a 45 degree angle.
      • Maintain the 45 degree angle of the RAM card until all pins are disengaged. Failure to do so may result in pin breakage.
Conor Most
crwdns2935283:004/14/14crwdne2935283:0
2,799 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-40, Maness Spring 2014 crwdns2935289:0Cal Poly, Team 3-40, Maness Spring 2014crwdne2935289:0
CPSU-MANESS-S14S3G40
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 112
crwdns2959996:0crwdne2959996:0 4,718
