HP 17-x061nr Disassembly
  1. HP 17-x061nr  Disassembly, HP 17-x061nr  Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 17-x061nr  Disassembly, HP 17-x061nr  Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 17-x061nr  Disassembly, HP 17-x061nr  Disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the laptop upside down, remove the battery by hand and the twelve 7.0 mm screws that are holding the back case to the front. Use a JIS #0 screwdriver to remove the screws.
  2. HP 17-x061nr  Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 17-x061nr  Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back the rubber footrests located next to the battery, on the left and right sides.
    • Remove the two 7.0 mm screws underneath the rubber feet using a JIS #0 screwdriver.
  3. HP 17-x061nr  Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the optical drive out and away from the laptop.
  4. HP 17-x061nr  Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 17-x061nr  Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 17-x061nr  Disassembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the computer over and use a plastic opening tool to wedge between the back and front cases.
    • Trace the perimeter of the laptop. Make sure to keep the tool inserted between the front and back cases. You will hear popping sounds as the back case becomes disengaged from the front plate.
    • Flip the laptop over and lift the back case off. Now you have access to all of the internal hardware.
Michael hansen
crwdns2935283:002/12/18crwdne2935283:0
415 crwdns2915208:0crwdne2915208:0
Washington State, Team S1-G1, Lobnitz Spring 2018 crwdns2935289:0Washington State, Team S1-G1, Lobnitz Spring 2018crwdne2935289:0
WSU-LOBNITZ-S18S1G1
I have a 17-x051nr but the steps are exactly the same. Thank you! (I never like peeling off the bottom feet unless I know for sure there’s a screw under there)
Frank Buccella - crwdns2934203:0crwdne2934203:0
i searched all over for how to do this with my 17 inch HP Elite Notebook. Your instructions were perfect! Thank you!
Bud Hines - crwdns2934203:0crwdne2934203:0
Thank you! Also worked for HP-14AN013NA
Martyn Jones - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 9,695
