HP 17-ca1022cy Hard Drive Replacement
  1. HP 17-ca1022cy Hard Drive Replacement, Remove bottom screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the bottom panel there are 9 screws (in yellow) on the back and two screws under the disk drive. The disk drive screw is in the red circle.
    • You'll have to remove the rubber feet to access 6 of them
  2. HP 17-ca1022cy Hard Drive Replacement, Remove drive bay: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 17-ca1022cy Hard Drive Replacement, Remove drive bay: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you remove the disk drive screw (blue circle), the drive should slide out of the chassis.
    • Under the drive bay there are two screws to remove.
  3. HP 17-ca1022cy Hard Drive Replacement, Pry off the top chassis: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 17-ca1022cy Hard Drive Replacement, Pry off the top chassis: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slip a thin prying tool in the seam between the top and bottom shells and work your way around the frame.
  4. HP 17-ca1022cy Hard Drive Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Picture of the motherboard
    • Pull up on the connector side of the drive, then pull toward the battery, taking care not to tear it.
Anadyr Elliott
crwdns2935283:012/02/22crwdne2935283:0
156 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 504
