HP 17-bs049dx USB Port Replacement
  1. HP 17-bs049dx USB Port Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the battery, simply push the tabs towards each other.
    • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
  2. HP 17-bs049dx USB Port Replacement, Back Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  3. HP 17-bs049dx USB Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  4. HP 17-bs049dx USB Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 17-bs049dx USB Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  5. HP 17-bs049dx USB Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
  6. HP 17-bs049dx USB Port Replacement, USB Port: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 17-bs049dx USB Port Replacement, USB Port: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws using a Phillips #0 screwdriver.
  7. HP 17-bs049dx USB Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 17-bs049dx USB Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 17-bs049dx USB Port Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At both ends of the connector ribbon, unclip both connectors.
    • Gently remove the ribbon from the unlatched area.
Logan McCarty
crwdns2935283:010/01/18crwdne2935283:0
313 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S7-G2, Thompson Fall 2018 crwdns2935289:0University of North Texas, Team S7-G2, Thompson Fall 2018crwdne2935289:0
UNT-THOMPSON-F18S7G2
crwdns2931471:06crwdne2931471:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 323
