HP 17-bs049dx Motherboard Replacement
  1. HP 17-bs049dx Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  2. HP 17-bs049dx Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  3. HP 17-bs049dx Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 17-bs049dx Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  4. HP 17-bs049dx Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
  5. HP 17-bs049dx Motherboard Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove screw (7.51mm) on USB port with "Phillips 0 Screwdriver".
    • Lift the USB port over and away from hard drive.
  6. HP 17-bs049dx Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 17-bs049dx Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift rubber black tabs located on the hard drive upwards.
    • Disconnect hard drive from motherboard by pulling towards you.
  7. HP 17-bs049dx Motherboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 17-bs049dx Motherboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 17-bs049dx Motherboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure to unplug everything connected to the motherboard.
    • Be gentle with this step.
  8. HP 17-bs049dx Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws (7.51mm) with a Phillips #0 screwdriver.
    • Once all of the screws are removed, remove the motherboard from the device.
Chanceline Mbiaoh
crwdns2935283:009/26/18crwdne2935283:0
207 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S7-G2, Thompson Fall 2018 crwdns2935289:0University of North Texas, Team S7-G2, Thompson Fall 2018crwdne2935289:0
UNT-THOMPSON-F18S7G2
crwdns2931471:06crwdne2931471:0
crwdns2942667:0crwdne2942667:0 931
