HP 17-bs049dx Hard Drive Replacement
    1. HP 17-bs049dx Hard Drive  Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • To remove the battery, simply push the tabs towards each other.
      • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
    1. HP 17-bs049dx Hard Drive  Replacement, Back Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
      • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
      • Rubber tabs will require force to access screws.
    2. HP 17-bs049dx Hard Drive  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
    3. HP 17-bs049dx Hard Drive  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 17-bs049dx Hard Drive  Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull outwards on the disk reader to remove from main frame.
      • This removal will require force.
      • All screws must be removed before removing disk reader.
    4. HP 17-bs049dx Hard Drive  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift back panel to access internal components.
      • You will need to use force to pry it open.
    1. HP 17-bs049dx Hard Drive  Replacement, Hard Drive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove screw (7.51mm) on USB port with "Phillips 0 Screwdriver".
      • Lift the USB port over and away from hard drive.
    2. HP 17-bs049dx Hard Drive  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 17-bs049dx Hard Drive  Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift rubber black tabs located on the hard drive upwards.
      • Disconnect hard drive from motherboard by pulling towards you.
crwdns2935229:012crwdne2935229:0
Logan McCarty
crwdns2935283:010/01/18crwdne2935283:0
313 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S7-G2, Thompson Fall 2018 crwdns2935289:0University of North Texas, Team S7-G2, Thompson Fall 2018crwdne2935289:0
UNT-THOMPSON-F18S7G2
crwdns2931471:06crwdne2931471:0
crwdns2935297:084crwdne2935297:0
This was SPOT ON! After searching high and low all over the fricken INTERWEBS for a decent manual, I landed here on your guide and am VERY thankful! KUDOS to you for sharing it!
John Hart - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
How much force am I required to put while lifting the back panel to access the internal components? I can go hulk on it but then I wouldn’t have a laptop later…
Stephanie Rose Brown - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 4,934
