You can use this guide to help you safely and effectively remove the screen from your HP 15-r137wm TouchSmart device.
Remove all ten (10) 5.5 mm Phillips #0 screws.
Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.95
Use a wide plastic opening tool to pry off the top casing.
Lift the cover off carefully as there are wires still attached to internal components.
Move the keyboard slightly out of the way to locate the connection.
Disconnect the small wire protruding from the motherboard underneath the metal plate.
Locate the connection between the power button and the connecting cable.
Remove the cable from the motherboard carefully.
Disconnect the connection between the keyboard the the motherboard.
Remove the four (4) 2.5mm by 3.5mm Phillips #0 screws from the metal retaining plate.
Lift the metal retaining plate off and away from the device.
Slide the CD drive out slowly by pulling it to the right. There are no screws attached, but there is a connection to the motherboard.
Locate the small connection on the motherboard and disconnect it by slowly pulling it away from the motherboard.
Remove the three (3) 2.5mm by 3.5mm Phillips #0 screws from the fan.
Remove the cooling fan from the housing carefully.
Remove the 5.5mm Phillips #0 screw.
Gently pull and slide the video card out of its connector.
Lift up tape, and then remove the power cable from its connector.
Remove all four (4) 5.5mm Phillips #0 screws.
Remove the one (1) 2.5mm Phillips #0 screw.
The screen can now be lifted out of place from the laptop.
