HP 15-r137wm TouchSmart Keyboard Replacement
  1. HP 15-r137wm TouchSmart Keyboard Replacement, Front Panel Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-r137wm TouchSmart Keyboard Replacement, Front Panel Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-r137wm TouchSmart Keyboard Replacement, Front Panel Assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure that the device is powered off and unplugged before removing components.
    • Remove all ten (10) 5.5 mm Phillips #0 screws.
    • Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
  2. HP 15-r137wm TouchSmart Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Anti-Static Wrist Strap
    $7.95
    • Use a wide plastic opening tool to pry off the top casing.
    • Be cautious not to crack the casing near the keyboard as it is quite fragile.
    • Lift the cover off carefully as there are wires still attached to internal components.
    • After panel is removed, use an anti-static wrist strap to ensure the motherboard does not get any external shocks from static discharge.
  3. HP 15-r137wm TouchSmart Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The connection for the track pad is still connected.
    • Move the keyboard slightly out of the way to locate the connection.
    • Disconnect the small wire protruding from the motherboard underneath the metal plate.
  4. HP 15-r137wm TouchSmart Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-r137wm TouchSmart Keyboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the connection between the power button and the connecting cable.
    • Do not lift the front panel off to far as the cable is still attached.
    • Remove the cable from the motherboard carefully.
  5. HP 15-r137wm TouchSmart Keyboard Replacement, Keyboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-r137wm TouchSmart Keyboard Replacement, Keyboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the connection between the keyboard the the motherboard.
  6. HP 15-r137wm TouchSmart Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-r137wm TouchSmart Keyboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four (4) 2.5mm by 3.5mm Phillips #0 screws from the metal retaining plate.
    • Lift the metal retaining plate off and away from the device.
Ross B Jacques
crwdns2935283:010/18/17crwdne2935283:0
881 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S4-G4, Julie Fall 2017 crwdns2935289:0UMass Dartmouth, Team S4-G4, Julie Fall 2017crwdne2935289:0
UMASSD-JULIE-F17S4G4
crwdns2942667:0crwdne2942667:0 551
