If you need to open your HP 15-g029wm to access its internal components, this guide will show you the process of removing the laptop's top plate. If you're encountering problems with your device such as overheating, freezing, random shutdowns, or needing to replace a component, you might refer to this guide. This guide can also be used if you need to remove the keyboard of your laptop.
Unplug any charging cord or accessories connected to the device before beginning.
Place the laptop bottom-side up on a secure, flat surface.
Slide each of the two switches that secure the battery to the left.
Use your hands to gently pull the disconnected battery out of the device.
Remove the following Phillips screws on the lower case:
Nine 5 mm
One 6 mm
Slide the optical drive directly out of its slot.
Remove the two 2 mm Phillips screws on the lip of the optical drive slot.
Use an opening pick to remove the two circular rubber feet near the laptop hinges.
Remove both of the 8 mm Phillips screws.
Use an opening pick to pry up and remove the left hinge cover.
Use an opening pick to pry up and remove the right hinge cover.
Flip the device face up and open the lid.
Insert an opening pick under the keyboard and pry around the perimeter of the keyboard until it fully releases.
Lift the keyboard slightly.
Use your fingers or an opening pick to unlock the ZIF locking flap that secures the keyboard ribbon cable.
Disconnect the keyboard ribbon cable.
Lift the keyboard off.
Remove two 5 mm screws using a Phillips screwdriver.
Insert an opening pick in the seam between the top case and chassis.
Slide the opening pick around the edge of the device to separate the top case from the chassis.
Slightly lift the top case up and away from the chassis.
Use your fingers or an opening pick to flip up the black ZIF locking flap.
Disconnect the ribbon cable.
Lift off the top case.
