This is a guide on how to replace the RAM on your HP 15-g029wm. This guide may be needed if you're encountering problems with your HP 15-g029wm's screen freezing. There is only one step in this guide that describes how to remove the RAM from your motherboard to replace it.
Unplug any charging cord or accessories connected to the device before beginning.
Place the laptop bottom-side up on a secure, flat surface.
Slide each of the two switches that secure the battery to the left.
Use your hands to gently pull the disconnected battery out of the device.
Remove the following Phillips screws on the lower case:
Nine 5 mm
One 6 mm
Slide the optical drive directly out of its slot.
Remove the two 2 mm Phillips screws on the lip of the optical drive slot.
Use an opening pick to remove the two circular rubber feet near the laptop hinges.
Remove both of the 8 mm Phillips screws.
Use an opening pick to pry up and remove the left hinge cover.
Use an opening pick to pry up and remove the right hinge cover.
Flip the device face up and open the lid.
Insert an opening pick under the keyboard and pry around the perimeter of the keyboard until it fully releases.
Lift the keyboard slightly.
Use your fingers or an opening pick to unlock the ZIF locking flap that secures the keyboard ribbon cable.
Disconnect the keyboard ribbon cable.
Lift the keyboard off.
Remove two 5 mm screws using a Phillips screwdriver.
Insert an opening pick in the seam between the top case and chassis.
Slide the opening pick around the edge of the device to separate the top case from the chassis.
Slightly lift the top case up and away from the chassis.
Use your fingers or an opening pick to flip up the black ZIF locking flap.
Disconnect the ribbon cable.
Lift off the top case.
Use a Phillips screwdriver to remove the three 5 mm screws that secure the fan.
Gently "walk" the fan connector directly out of its motherboard socket.
Lift the fan up and out of the chassis.
Use two opening picks to disconnect the display cable.
Use an opening pick to gently "walk" the white speaker connector directly out of its port.
Remove the four 3 mm screws that secure the motherboard.
Lift the front edge of the motherboard slightly.
Use an opening pick or your fingers to release the ZIF locking flap.
Pull the ribbon cable out of its port.
The motherboard is now fully disconnected and able to be removed from the chassis by lifting it out with your hands.
Remove the following components for your new motherboard: Heatsink, RAM, CMOS battery.
Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module
Slide the RAM module straight out of its socket.
