Is your DVD-ROM cracked or smashed? Or it can not open? Well, you are in luck, this replacement guide will help aid you replace the DVD-ROM. This guide is helpful if the DVD-ROM doesn’t work.
This guide will walk you through step by step on how to replace the DVD-ROM. Is the DVD-ROM on your computer not working and you found out it costs a lot to have them fixed? Well you are in luck. The following guide consists of the steps to remove the DVD-ROM from the computer while also showing you the prerequisite steps to be able to remove the DVD-ROM. This guide allows you to replace your DVD-ROM yourself for free rather than having to pay someone to do it.
Flip over the device so that the bottom is facing you.
Remove the screws using the Phillips #0 screwdriver.
Drag the optical drive horizontally until it detaches from the port on motherboard.
Remove the optical drive from the device.
